Texas_Two_Stepp's avatar
Oct 02, 2015
Casita phantom load
I have a friend with a 2010 Casta who is having a problems with battery drain. She has a 12v deep cycle Optima battery (75 ah rated)dated 6/12. She has a monitoring device that plugs into a 12v receptacle that she uses to determine the status of the battery. She is dry camping and runs her Honda generator for about an hour each day and gets a reading 12.7 which drops 12.4 fairly quickly (I verified this with my multimeter). The charging voltage at battery is 13.5ish with a Honda 2000. Converter is ETD 7345.She has been plugged into shore power within the last 4 days. First thing I did was charged the battery for 2 hours and then checked for amp draw with everything turned off and was getting about 2 amps dc. I checked the circuits and found that the drain was coming from the water pump/fantastic fan/light circuit.The ground on the battery seemed loose when I took the wiring loose to test it and I messed with the switch on the water pump and got the amp draw down to .4-.5 amps.I asked her to use go about her normal routine and see what happens. In thinking about it it seems that .4 amps is a large phantom load for this unit. What are your thoughts as to how I proceed from here?
  • Bobbo's avatar
    Bobbo
    Explorer III
    You say a "ETD 7345." I bet that is a Parallax/Magnatek 7345. That is a poor converter/charger. That is the one my RV came with. I finally got tired of poor performance and upgraded to a Progressive Dynamics PD4655 after 4 frustrating years.
    A charge rate of 13.5 is going to take days to recharge a battery. You really do need at least 14.2, and that charger is not going to do that. Her other option is to buy a battery charger at Walmart or AutoZone, and use that to charge her battery.
    Even with a 14.2 converter, or a battery charger from the store, a 1 hour charge won't be enough. You need to run it about 3 hours to get a good charge.
  • A 75 Amp hour battery is a group 24, and an Optima is a horrible choice for a deep cycle battery. It is not enough battery for her current level of amperage consumption... 37 amps in 24 hours, and that battery is being worked to death with a 50% or greater level of discharge. Great way to destroy a deep cycle battery.
    A 2012 dated battery, by Optima, is about done by now... she really needs to complete an equalization charge on that battery to 16.0V pronto, like in yesterday, to see if it is salvageable.
    Do a search on how to equalize charge a battery here by mexico wanderer
    What she needs is a good 30 amp charger that will output 14.8V at the battery, and a run cycle of a minimum of 2 hours, first thing in the morning, on the generator.
    I'd suggest 2 things... a real industrial grade deep cycle battery like a pair of 6 volt GC-2's from Costco, wired in series, for 210 amp hours, or find a good used Teleco 140 to 150 amp hour 12V AGM type battery for sale on Craigslist, and charge it at 13.6V.
    The charge controller she probably has now in her Casitas, is for RV parks and pedestal full time hook ups, not for dry camping and boondocking, which it is inadequate for.
    She needs to run the fans and water pump only when absolutely necessary, and I see a 160W folding portable solar panel in her future, if she want's to keep the generator turned off and quiet.
  • Start pulling fuses. What kind of charger is the Honda powering? Assumptive energy management always leads to this kind of situation. She needs to learn to be smart enough to ask the right questions and learn.
    A large enough Honda to power a 60 ampere charger would not be overkill here.
  • With everything off the phantom draws are the propane detector and radio memory in my TT. I put a switch on the radio and the detector draw is 70ma (.07A) IIRR.
    Yes, you need 14V+ at the battery to get a good charge. I mounted a deck-mount IOTA to the ceiling of the pass-through. 3' cable run to the batteries. The problem with a long wire run to the inadequate WFCO converter was solved.
  • wolfe10 wrote:
    .4 amps is probably a reasonable phantom load.
    As far as generator run time, we really need to know what charger she has. 12.7 VDC will NOT fully charge a battery. Particularly if paying to run a generator, the charge voltage needs to be 14 or slightly higher.
    So, my first suspect is the converter/charger, not the battery.
    The charging voltage is 13.5ish with a Honda 2000. Converter is ETD 7345. Sorry I left that out.
  • .4 amps is probably a reasonable phantom load.
