I have a 2004 Four Winds class c rv. Small the seams have a pliable caulk in them. It has oozed out from under the seam covers and the window gaskets. I am worried that the seams aren't sealed any lon...
I bought it new. The putty was pushed out a little then but now it seams worse. The only thing on it was the putty. As I am understanding it, the proper procedure is to use butyl putty instead of the white stuff and then use the Geocel the seal it off better after the trim is tightened back down. Am I correct? Thanks for the welcome.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
