wa8yxm
May 24, 2020Explorer III
The Suspect list (And you are correct the cover did not likely cause it. But mounting the cover might have)
Blown fuse
Bad Switch
Bad motor
Wiring issue (mouse or a screw (mounting the cover) through the wire.
Suggest a volt meter or test light to check for voltage both sides of the switch and also to test the ground (Ground at the fan)
Blown fuse
Bad Switch
Bad motor
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
