dryfly
May 24, 2020Explorer
As with any electrical problem, start at the "problem" and work back to the power source. Make sure switch is on then, using a multi-meter, determine if 12 volts DC is present at the fan motor. If it is, you have a bad fan motor. If not move on to the switch, etc. It's really difficult and time consuming to "guess" a solution to any electrical problem.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
