dryfly
May 26, 2020Explorer
OK, I'm not following your explanation of your use of the multi-meter, but a simple way to test the fan would be to pull the fan motor out of the vent, and connect the two leads, positive and negative, to a 12 volt DC source. Use your RV or vehicle battery.
Above you state your fan power switch "doesn't work". If you know the switch is defective why not replace it??
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
