RJsfishin
Sep 08, 2017Explorer
If I wanted to change that cable, I would shut off anything that mite be causing current to flow thru it, (common sense?) and just change it.
There is no harm to be done by a disconnect in the 12v DC system, other than loosing some programing memory etc. Otherwise, do like the big boys do, connect a 12v power supply across the main leads while you change it.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
