alogo4u's avatar
alogo4u
Changing out battery
Need to replace engine battery. On the fuse panel on firewall there is a notice. All relays should be off prior to installing new battery.If I turn off the chassis battery at the inside door switch shouldn't this work. Have 2 switches one for chassis and the other for coach. Just confused. Thanks guys!
  • Ignition key off, switches in cab turned off. Don't forget you're going to lose ECU codes. If you have a vehicle which DEMANDS a hundred dollar dealer visit to reset the codes I would consider the use of a cigarette light plug-in power device (a Code Saver)
    Read and follow the Code Saver directions exactly. Point-by-point.
  • Thanks for the responses. Just wanted to make sure I don't fry anything. LOL
  • My Coachmen has a similar warning notice, and the chassis battery switch inside the entry door next to the house battery switch disconnects everything except a couple of items that are directly wired to the battery. I recall that one is the radio memory, and the other might be the ECO memory, but I'm not sure of that. When I have to disconnect the chassis battery, I have a gadget that plugs into the dash 12-volt outlet and connects a standard small 9-volt battery battery to the wiring to maintain the memory settings.
  • The inside door switch controls the HOUSE, not chassis batteries unless your coach is wired VERY different than norm.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
