azbohunter's avatar
azbohunter
charger side of Magnatek 7300
I have a suspicion that my charger is not putting out DC to recharge batteries in my rig. I have lights and 12 volt to accessories in trailer but batteries are dead. I am not sure how to test it even after reading several articles and watching YouTube videos. If the battery is not hooked up I get nothing coming out of the dc side of charger, I have 110 going in at the lugs on the charger, the fuses for reverse polarity and charger are both good. Is there a way with a multi tool to test output on the charger side?
Thinking about just replacing it with a Progressive Dynamics 4655 and being done with it.
  • The batteries will last much longer on the Progressive converter, as it does not cook them. I have installed two in Magnatek/Parallax panels, very easy job. On my Winnebago motorhome, the converter and fridge 120v were on the same breaker so I wirenutted both wires to a short pigtail into the breaker (originally they were both in one wire thimble). The Bigfoot trailer had the converter on its own breaker. By all means install the DC fuse panel, It requires a little wire bending and routing changes as the lugs are in slightly different locations, but you get led warning lights for each fuse to show they are blown and you get a button to control the charge wizard in the converter, plus and LED to show converter status.
    USE A 3/8 wrench to hold the square terminal blocks while you tighten the screws so you don't twist the terminals off the printed circuit board.
    Charles
    Charles
    Some great information, thank you.
  • Just a follow up and thanks for help and suggestions. Installed the Progressive Dynamics 4600 this morning. Pretty easy install really and all seems to be working as advertised. Glad to have the situation resolved and looking forward to stronger batteries and longer battery life.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
