gsh wrote:
So, maybe I need to invest in a more powerful charger.. Even when camping.....
Im pretty sure you cannot hookup a secondary charger to your batteries when they are connected to the trailer. So, would it be best to instal an isolator so at the turn of a switch disconnect my batteries from the trailer and then connect say a 40 amp charger to my generator and charge them from there? 1 hour in morning, and 1 hour a night, will probably put more juice back into them then if they were just charging from the trailer converter!!
yes no? maybe so?
What generator? Honda 2000 will drive about 70 amps into the battery. Larger generator can put 120 amps into four GC2 low on charge.
May as well post your converter model. Some just need a wizard or IQ controller to start breathing fire into the battery. Or you can upgrade the converter as needed.
That 40 amp portable charger is a bit slow but will max out a Honda 1000.
