ABendage's avatar
ABendage
Charging a powerwheels battery with my solar setup?
Hello everyone, long time lurker, first time poster here.
I pretty much exclusively boondock in the wonderful mountains of Colorado and as such have a 100watt solar setup on my camper. It is way overkill for my little camper and usually the charge controller says the battery is fully charged by noon. It's an older camper so the fridge uses no electricity when on propane, the CO detector runs off of AA's, I have all LED lights, and my little furnace only pulls 1.7 amps and it is sunny almost everyday in Colorado so I have a surplus of power.
I like to bring my son's powerwheels with when camping and it seems silly to invert 12v to 120, then back to 12 to charge with the normal charger. Can I just wire in a pigtail off of my camper battery and let the solar set up do the work or will it mess things up having one 100ah battery and one 12ah battery hooked up? My thinking is the PW battery typically only needs 6-7ah to charge it up and my solar puts out 4.5ish through most of the day so it'd only need to be plugged in for an hour or two. Will that work or does having two different size batteries hooked up in parallel not work?
Thanks!
  • ABendage wrote:
    Thanks for the replies!
    The battery is a 12v 12ah SLA battery. I use a Schumacher 1.5 amp battery charger/tender to charge it, the stock chargers are junk and horrible for the battery. Charging voltage should not be an issue, the Schumacher charges at 14.4 and floats at 13.6 and my charge controller on the solar does about the same. I guess 4+ amps would probably be too much for that little guy, wonder if there is a way to regulate that down or if I should just find a small true sine wave inverter to run the Schumacher.
    Stop.
    That is NOT a SLA battery.
    It IS A GEL CELL BATTERY (yes, it is "sealed" and yes, it is a "lead/acid" TYPE of battery BUT it stops there since the electrolyte is GELLED and not a liquid)..
    a 1.5A charger is WAY TOO MUCH for that battery, and the Schumacher has to high of a float voltage (it should be about 13.2V for a gel battery).
    Using a 1.5A charger is going to DRY OUT THE GEL BATTERY rendering it useless very quickly not to mention putting the battery into a potential fire hazard situation.
    The ORIGINAL CHARGER for the Power Wheels is perfectly fine and has a much lower amperage of 1.2A.
    If you want a quick charge, they DO have a "SMART" quick charger specifically designed for Power Wheels batteries which can recharge in 3hrs.
    HERE
    I would NOT recommend connecting that battery directly to your RV 12V power/charging system. The battery can and will charge at too high of a rate and the results may not be pretty.
    Just use an inverter AND THE PROPER POWER WHEELS CHARGER.
    Stop.
    HERE
    Sorry, was using the term Power Wheels as a product type instead of brand, the brand is Peg Perego and it is in fact a SLA battery. Sorry for the confusion.
  • SLA is a bit of a general term. If you have the charging specs and follow them.... go for it.
    GELL does need amps/volts limited or the gelled electrolyte can separate from the plates from gassing.
    Just went out and looked at the battery case and it does have the charge specs on there, 13.6-13.8v standby, 14.5-14.9v cycle, and current max at 3.2a.
    So, voltage we are in good shape, amperage questionable, because the house battery might take some of that, but either way, I have an ammeter mounted and always know the charge rate, so I can just avoid charging it during peak sun. I think I'm going to give it a whirl, especially as seldom as this will be done, probably less than 5 times a year.
    Thanks for the insight everyone!
  • I play w/ scooters and other electric stuff all the time.
    I am very familiar w/ that 12 ah battery, and it is an AGM SLA battery, trust me.Those batteries will charge just fine paralleling them the the RV batteries.
    Many of the smaller SLA AGM batteries out there are called Gell, but in reality they are not true Gell as we've learned to know them. A genuine Gell battery would never be used in that kind of a deep cycle service.
    The next post show what I use to parallel to my RV house batteries, whether it be my boat battery, or my electric scooter batteries.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
