Mark_Naturist_C's avatar
Feb 10, 2020
Charging Camper/Coach Battery with Running Lights Lead from Flat-4
I am installing a brake controller on my trailer. Among other things this thing allows me to connect my camper with trailer brakes to a Flat-4 Hookup. The link is below. My question is the way the thing gets power with the flat-4 is the running lights power. If I simply Jumper the 12VDC line from the Running lights line in my 7-way (Camper) to 4-flat adapter (Car) adapter will it work Okay and also charge the coach batteries. Or will it blow up? (Melt wires/blow fuses)
I'm looking for anyone that has tried to charge coach batteries, or simply powered a refrigerator, from a flat-4 running lights lead, (running lights must be turned on).
Thank you for any help.
AUTOWBRAKE
  • Sounds like someone should've bought a vehicle with a real factory tow package.
  • Watch the review by e-trailer. They don't recommend using on the 4 wire because the wiring is not heavy enough.
  • Very clever idea
    1. IF your Trailer battery is bad or dead or below 11 volts, you will NOT have Trailer Brakes at all
    2. 4 Way flat gauge wiring cannot supply the needed power, especially if you attempt to tie into the Running light circuit. AND, I would worry about the Tow vehicles gauge wiring and fuse set up in its running circuit.
    3. This system needs to be installed with a standard 7 way Bargman Trailer plug, that has the required Charge line run to the trailer. If no charge line to the trailer from the tow vehicle, the Brake system will slowly deplete the Trailer battery every time the brake system engages.
    4. IF you have a 4 way flat on your truck(tow vehicle) AND your trailer, something is wrong unless the trailer is a utility trailer. RV camping trailers always have a 7 way Bargman plug on the trailer.
  • jdc1's avatar
    jdc1
    Explorer II
    ScottG wrote:
    No, the flat 4 cannot carry that kind of load.
    Wires are wayyyyy undersized to help you.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 25, 2025
