pianotuna
Oct 01, 2015Nomad III
Hi,
I have 566 amp-hours worth and if I've been using load support to run the various and sundry systems in the RV while on a 15 amp supply I do 'see' 80 to 90 amps of recharging.
My Magnum is capable of 125 amps of battery charging. Unfortunately the Magnum does NOT like most gfi outlets, so my back up charging is a PD 40 amp unit with wizard. I've not had to use the PD with the 'new to me' telecom jars.
When on load support I've seen a draw of 114 amps. Voltage stays at about 12.3 under that level of demand.
