TurnThePage's avatar
TurnThePage
Charging car battery, how high v is too high?
Not specifically an RV issue, but... Our two year old car wouldn't start today. A quick check of the battery showed just over 8 volts. I connected a Harbor Freight 2/10/50 charger on the 10 amp setting. The multimeter immediately showed 14.3v and was at 15.7v 15 minutes later. I disconnected it, fearing it was climbing beyond what was safe.
Thoughts?
  • pianotuna wrote:
    Hi,
    When a battery exhibits that kind of behavior it is pretty much done.
    15.7 is definitely too high for an RV (fridge board is 15.4), but I know not about a car.
    It depends on the model of refrigerator. This is from Dometic
    DIAGNOSTIC SERVICE MANUAL
    AMERICANA & AMERICANA PLUS
    RM 2351, RM 2354, RM 2451, RM 2454
    RM 2551, RM 2554, RM 2652, RM 2662
    RM 2663, RM2852, RM2862 & NDR1062
    dc
    Voltage
    The operational range
    of the unit is a minimum of 9.6V DC to a maximum of
    22V DC. The unit will automatically shut down until volt
    age has decreased to 18V DC.
  • The charger is working correctly.
    The voltage you were reading was what the charger was putting into the battery to bring it back up to capacity. Once the battery gets near to 100% the charger will then switch to a trickle charge mode. I have a "smart" charger that starts out at about 13.2 volts & cycles in small increments up to 16.0 volts over the charging period, once the battery reaches capacity, the charger senses this & backs down voltage.
  • Hi,
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
