wa8yxm
Jan 09, 2015Explorer III
MR MAC wrote:
Staying at Sons house in NC about a wk., too far from ele. plugin, any one how long it would take to charge batt. with a charger plugged in to MH with gen. running. May need to use furnace at night.. Also would charging cause any damage to converter as both would be sending current to batt. and is this a bad thing to do. Or do I have to disconnect batt to charge with a charger?
Second question: Would converter be damaged: NO, not at all, there are devices that act as electric check valves that protect both the charger and the converter.
How long will it take.. Now that is complex,, For Bulk charging you need to know the output of the converter, the output of the charger, the amount of load on the system and the capacity of the battery and the state of charge.. Then You add the charger and converter, subtract the loads, Multiply battery capacity by state of DISCHARGE (IE: if batteries are 60 percent SOC you multiply by 0.4) divide product of multiplication by the sum of addition/subtraction and that is hours to 90% in theory,, then it's 2-4 hours to top it off.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
