abochoa's avatar
abochoa
Charging problems
I am having issues with the electrical system which I am not too familiar with and after reading some of the questions on this website, I have learned a lot about the elec. System, and I am hoping I can get help here figuring out my problem. I own a 26 ft. 2005 Tioga on a Chevy chassis, and in 2011 the batteries were going bad (from lack of maintenance) so I bought 2 24DC’s from Walmart. Being unfamiliar with the batteries in the RV, I thought they were the same type so I hooked them up in series, after a few sparks I realized that originally it had came with 2 6 volt batteries instead of 2 12’s so I hooked them up in parallel and all was good (except for my grey and black water indicator lights on my monitor didn’t work anymore and a replaced GFI in the bathroom). After 3 years the 2 12’s started failing, they would only hold a charge for about a day, and then I would need to run the engine for a few hours to charge them, (that is when I noticed the generator was not charging them) so I bought 2 Interstate 6 volt GC2’s with 232 Ah, and after I installed and connected them in series they had an initial voltage of 12.28. The problem I am having now is the only time I get a charging voltage is when the vehicle engine is running, I checked the output on my WF 8845 converter with shore power and the batteries disconnected and it was zero. I checked it with batteries connected and it was 12.28. So I started the Onan 4000 gen. and plugged the shore cord into the RV’s storage bay outlet and the batteries still read 12.28, so I started the engine and after about 10 minutes I checked the batteries and they were at 13.34. During all this I noticed the fan on the converter never started but I don’t think I ran it long enough to get hot just warmer. I intend to upgrade the converter to a PD9260 as soon as I can figure out the charging issue. Besides batteries and the 1 GFI I have not had any other issues. So I am wondering if another component has failed like a transfer switch, besides the switches for the aux. batteries and gen. start on the wall monitor, there are a couple of toggle switches on the dash, one to start the generator the other to boost the chassis battery. I am not familiar with the components in my battery box (they look like relays and solenoids) or if there is any located anywhere else. Hope there is enough information for someone to help me. Thanks in advance.
  • I wonder whether your current converter blew a fuse when your hooked up your batteries incorrectly - I know PD converters are fused - don't know about WFCO. In the interim use a battery charger as replacement converter.
    BTW - it takes a long time to charge a battery and you would have to run your engine for a very long time to charge a depleted battery.
  • Get rid of the WFCO. I went thru two of those cheap suckers before getting a PD.
  • Old-Biscuit wrote:
    Your charging problems are that WFCO that is NOT charging......when on shore power or running generator the WFCO converter/charger is suppose to charge the batteries.
    Check that the WFCO is getting 120V AC power (feed from an AC circuit breaker directly or thru an outlet it is plugged into)
    With AC power to it.....should have at minimum 13.2 V DC on the output with batteries disconnected.
    Best scenario....yank it our and replace with the PD
    9260
    X2. Your description says either the WFCO is not getting 110VAC from generator/shore power or it is broken.
  • I verified the voltage at outlet converter plugged into was 120v. only thing I didn't do was disconnect pos. and neg. cables from output side of converter and check output. I will do that tomorrow. thanks for the help.
    Alan
  • Your charging problems are that WFCO that is NOT charging......when on shore power or running generator the WFCO converter/charger is suppose to charge the batteries.
    9260
  • Remove the WFCO and bench test. 120v in, 13.6 volts out. Even if it tests good get the 9260 and put it in.
