chilly81's avatar
chilly81
Charging RV batteries with EU1000i and Charge Wizard
I've been reading some seemingly conflicting information about how you should use a small generator to charge a camper's batteries... just hoping to clarify.
PD9140 Converter (40amps@13.6 from 600W 120v A/C - (5 amps))
w/Charge Wizard (14.4v@30+amps to 90%, then 13.6v.... then 13.2v).
Honda EU1000i (Rated 7.5amps@120v. Not sure about DC rating)
So as I see it, the Honda will provide as much juice as the converter would be able to pull off of shore power anyway. So is it as simple as just plugging my converter/RV into the Honda for the few hours it should take to get to 90%. Then just turn it off when the charge wizard indicates it's in the slower charge mode - as it's probably diminishing returns w/r to generator run time (many hours for the last 10% if I understand right).
Or is there a better way to do it with DC?
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
