Dalo's avatar
Dalo
Charging trailer deep cycle batteries
Hi all, I have a 2004 HR Alumascape which has given me 18 years of fun. We mostly dry camp. Usually I run the 2000W Yamaha generator every 2 or 3 days for a couple of hours to keep the batteries charged. I have read many comments here about older converters not being very good at charging the two deep cycle batteries. My converter is the Parallax 7355. So far, after 18 years this has worked okay for us but I just had an idea- What if when I fire up the generator and plug in the trailer power cord I also hook-up a 10amp variable rate charger connected directly to the battery posts. Would not this shorten the run time needed to bring battery charge up?
  • I don't know anything about your converter model but it is likely single stage which means it charges at a fixed voltage, usually about 13.5 volts. A multistage converter/charger will start at a much higher voltage, around 1.43 volts and then taper off. This means much less time needed for charging and more likely a better charge with longer battery life.
    I recommend you check the bestconverter.com webpage and then discuss recommendations with the owner, Randy. He knows his stuff and the prices and services are good and you know you will get the right replacement. I replaced my converter/charger and greatly reduced generator use. Most of my charging is with solar but when that does not work, I still need a generator.
  • Haha, yes we get a lot of sun. Actually we are heading out Labor Day for two weeks and usually try to get a shady spot. Just was reading about the Parallax 7355 and still don't understand how to figure the battery charge rate from the converter. It's variable but Parallax states in the manual that it puts out a rate of about .5amp. I know it starts out at a higher rate of charge but quickly drops to .5amp.
    Anyone have any idea of how long it charges initially at a higher rate??
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
