CA_Traveler
Nov 21, 2014Explorer III
Something is not right here. The ground does NOT pass THROUGH the GFCI and hence it cannot have 120V from the GFCI or elsewhere unless it's open or a ground could be connected to 120V somewhere but a properly wired GFCI does NOT pass the ground through and a correctly wired ground coming into a GFCI will be "earth ground" and not be at 120V.
A GFCI does have a ground connection for the ground lug and modern GFCI's can also detect a neutral to ground fault. A GFCI does pass through the hot and neutral and in fact detects a current difference between these two wires. Perhaps there is a wiring problem upstream or the wiring colors are misleading vs actual connections or ???
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
