wa8yxm
Nov 23, 2014Explorer III
Here is something I will describe.. You have a "Water use reducer" washer this is a small washer with a tiny hole (lets make it a pin hole) in it in a line, When you shut off the valves a pressure gauge on the down-line side of the thing shows full line pressure.
but when you open a valve the pressure drops to zero and water basically drips out of the faucet.
I have actually seen this in electronics, the DIGITAL Volt meter showed normal voltage because it used less current (water) than the fault (Washer) would pass.
But a test lamp found it and fast.. (And the fault (washer) was thus removed and full flow restored).
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
