wa8yxm
Dec 12, 2013Explorer III
There are indeed dual-conversion power line conditioners that can take a very dirty input and give you pure sine wave out... They cost more than a very good generator however.
If your Chinese model is an INVERTER unit, then I'd feed the trailer via a surge guard such as the Progressive Dynamics. it will sense most issues and shut you down BEFORE damage happens.
If it's an open frame type (Contractors type) GET A NEW GENERATOR or a whole bunch of earplugs for your neighbors.
WHile it is true that SOME portable generators are.. Rather nasty. the key word is SOME.. Generally small generators (Under 5,000 watts) with a motor that spins at 3000 (50 hz) or 3600 (60hz) RPM are the bad ones.. But even there there are exceptions.
The only way to be sure.. Is testing.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
