pewterman20 wrote:
Sorry about not getting my question in the last post. Does installing an n-line check valve also eliminate the cycling problem I'm having with the pump when I turn the water off?
Water pump cycling when there is no demand (no faucets/no leaks) is another sign of pump check valve leaking.
Installing the in-line check valve in SUCTION line of water pump will stop water from flowing backwards thru pump, overfilling fresh water tank when on city water AND stop pump cycling due to a leaky pump internal check valve.
(installing it in discharge will only stop filling of tank......pump will still continue to cycle because pressure inside pump will decrease due to leaky check valve which will cause pump pressure switch to close so pump will go burrp (short run) to make pressure switch open. This can causse damage to motor)
