dougrainer
Oct 12, 2019Nomad
obiwancanoli wrote:BFL13 wrote:
Seems you were running on inverter for your 120v needs and that ran the batteries down enough so the inverter shut down. There would still be enough battery to run the usual 12v things -lights, fans, etc.
When off-grid, you need to "power manage" what the inverter is running so the batteries can keep up. Put the fridge on propane, WH on propane, limit use of 120v appliances. When not watching it, unplug the TV set, don't just turn it "off", which leaves it on. All kinds of tricks to get by longer before you need to recharge the batteries.
At some stage you do need to recharge them, no big deal, but best if they can be done during the day instead of at 3am! :)
My rig is a 2017 Newmar Ventana LE.
My understanding was that if I needed to run ANYTHING - i.e., my lights, tv, clock radio, microwave display - that the inverter needed to be "on"... the fridge does run on propane when not plugged into shore power, as does the WH.
Yes, you really need to go to a NEWMAR dealer and have him explain the system. The Inverter should NEVER--NEVER be ON when on solar power or even boondocking, unless you have a need for the 120 appliances that run THRU the Inverter. You do NOT need to keep the Microwave clock ON. Lights are straight 12 volt and do NOT need the Inverter ON. The clock radio and the TV's do need the Inverter ON when boondocking. When on Genset or Shore Power, you do NOT need the Inverter ON. It has pass thru 120 power so it is not supposed to be ON. Your solar system CANNOT keep up with the 12 volt draw having the Inverter ON draws. Turn the Inverter ON when you need those 120 appliances ON when Boondocking and then once done turn the Inverter OFF. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
