dougrainer
Oct 15, 2019Nomad
obiwancanoli wrote:larry cad wrote:obiwancanoli wrote:larry cad wrote:
While you have not specifically stated such, it sounds like you might have a residential frig rather than an RV type frig. If that is the case, then yes, you need the inverter on to keep the frig cold.
It also might help if you tell us more about the system such as type of inverter and inverter remote control.
Lot's of good advice here.
I have an RV style fridge - shore powered or propane - a Magnum Standard Remote Control, and a Magnum ME Series Modified Sine Wave Inverter
The magnum can be conveniently wired to your Onan Quiet Diesel Generator to operate in "auto gen start" mode which will start your genny automatically if your batteries get low. You have the option of setting the "low" voltage where it starts. This is all done on the magnum operator panel, the one with the rotating know.
I believe I can set the AGS from inside the RV, though there is also an Auto-Gen unit/control box inside one of the external bays... need to investigate that better...
Magnum has 2 owners manuals. One for the Magnum Inverter and one for the Remote operation. The module in the storage bay is REQUIRED for the Auto Genset function. You do indeed set up the Auto Genset from inside the RV on the Magnum remote. This should be your remote instructions. Doug
https://www.magnum-dimensions.com/sites/default/files/manuals/owners/64-0003-Rev-G-ME-RC_Web.pdf
