houstonstroker
Oct 15, 2019Explorer
When boondocking the best way to preserve battery power is to run everything you can (fridge and water heater) on propane. It might be that your entire coach is inverted. That means everything running on 120 volts AC goes through an inverter. So if off grid and you need anything requiring 120 volts AC then yes your inverter needs to be on. But turning off your inverter would still let anything requiring 12 volts DC to operate. All depends on how the coach was set up.
