larry_cad
Oct 15, 2019Explorer II
Z-Peller wrote:
When you are plugged in to shore power most rigs have a "converter" wired into the system that keeps your batteries charged. When you are using "inverter" for 110v power, you must switch off the "converter" breaker on 110v breaker panel, otherwise you have the "inverter" using up battery power running the "converter" which is a battery charger. Big time loosing proposition. Will run your batteries down very rapidly. Sounds like this is what is happening to you in addition to other things mentioned....
With the magnum inverter/charger in his diesel motorhome, all of that is done automatically and there is nothing to worry about. The "charger" is integral to the magnum and operates to charge the batteries only when plugged into shore power.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
