j-d
Nov 23, 2013Explorer II
I've wire-wheeled them. Was thinking a Scotch-Brite Pad would work too. Even FINE steel wool. With that you could use brake fluid as a lubricant. But if they're pitted on the sealing surface, you need new pistons.
Did you order rebuild kits for F-700?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
