ScottnSherrie
Nov 28, 2013Explorer
John&Joey wrote:ScottnSherrie wrote:
The hardest part is holding up the heavy caliper and getting the key and spring started to install them. I think I'll try to figure out a way to hold the caliper up with one of the scissor jacks I use to stabilize the motor home.
Not sure what you got going on there, but sometimes you can wire up the caliper so as to take the weight off of the hose.
I'm replacing all the hoses and pulling calipers to rebuild. Original problem was overheating brakes possibly due to the 25 year old hoses failing.
