wopachop
Sep 18, 2019Explorer
MDKMDK wrote:Thanks i just looked that up. They have a drain clean and a septic treatment. Depending on the advice other people give i might do the air pressure first and then get on a routine of septic treatment.
If you're not in a huge hurry, there's a product called Bio-Clean that literally eats the stuff that is probably blocking your system. It does take a few days to work, so it's not a quick fix, but it isn't expensive either. I used it to clear a clogged basement drain last year. Took about a week of adding the stuff to the open end to work it's way through about 15 feet of sewer pipe. After a week, I could blast water through it with a garden hose. Can be used for maintenance, as well.
There are all sorts of similar products out there, I'm sure.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
