DutchmenSport
Sep 19, 2019Explorer
Without a leaching field, the solids will just sit there and continue to pile up while liquids flowed away. What you probably have in those barrels is a gigantic block of solidly compacted mess! Chances are, it won't even pump out. Nothing is going to get pushed through any holes with any kind of pressure. I think, if you can get away with it, your best option is to simply cover the old barrels up, seal them off, and dig out a new one. And...as stated above, add some leaching lines, and use Rid-X often to keep those solids broken down and in a liquid state.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
