MEX,
All wires are that were cut out are connected at both ends. All functions have been tested by plugging into vehicle. A second test was done by jumpering black (pos) on the trailer plug to each light function and all worked except clearance lights which should have come on with the tail lights. What I can't see are the wires from cut end to cut end because they are hidden in the overhang and will not pull out, must be clamped in there. Maybe the power for the clearance lights are spliced on in the overhang and that is why I cant find them. Next test it to apply power to king pin cut end green and white and see if they come on.
