enblethen wrote:
That is a case grounded relay. The two large posts are the feed and load.
It could be the charge relay and auxiliary start relay.
The circuit breaker would have two posts and be able 0ne inch cube. Could be metal or plastic.
Do you have a switch on the dash that says AUX on it?
This is on your signature Storm?
Yes and yes. Switch on the dash and it's a storm. Is it supposed to switch on its own? Why would charging amps drop?
My converter is hooked direct to the batteries. So I'm just confused as to what is happening.
