ktmrfs wrote:
judelaurenzo25g wrote:
ktmrfs wrote:
rather than blocking vents, replace the vents you have with vents that you can change airflow and airflow direction.
aireport vents are the ones I used.
https://www.amazon.com/5840BTW-Bright-White-Aireport-Conditioner/dp/B004P1WTVI/ref=sr_1_7?s=automotive&ie=UTF8&qid=1499979092&sr=1-7&keywords=ac+ceiling+vent
I guess my subject line wasn't thought out very well... These are the exact vents covers I was looking at. So I can cut the air off when I want in 3 spots.
Did you used to use them to cut off the air flow? Did your AC ever freeze over?
Thanks,
JL
use them all the time to either cut off ac to the bedroom or living area. never had an issue.
but I also added more vents in the ductwork so I still always have at least the original number of vents open. I added two more in the bedroom, 1 in the bathroom and 2 more in the living area in addition to the original vents. then replaced all of them with aireport vents.
adding more vents helps as well.
Adding more vents is a whole other monster. I'll google it or youtube it, see what I find.
