time2roll
Nov 26, 2018Nomad
OK maybe I misunderstood. 'Coach' battery I assumed was the house battery not the chassis battery.
Whatever the source battery... you need to check voltage and trace it back to the fuse block that distributes power to the accessories.
Not fully clear on what is not working as expected. Could be the house battery is shot. With the chassis engine running the alternator voltage might just run over the house battery to your lights and accessories. Could be a loose house battery terminal. Need to get a meter direct on the terminals.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
