papa45's avatar
papa45
Coach Lighting Short
Spring Break, last week, the 12V bedroom ceiling lights went out. Fuse is good. Other lights on the same circuit work OK. There is no power to the wall switch. Can't find anything loose on the power panel or converter. I assume something shook loose, but electrical code should not allow any connections that are not located inside an electrical box. I can't guess how the wiring is routed inside the floor and/or walls. Any suggestions?
