uncle_t's avatar
uncle_t
coach tilting
i have an 06 monaco knight DP equipped with 8 air bags. when i store it i dump all the air out of the system (gauge reads 0-0) the coach lowers a bit and is level. one day later the coach has a 2 to 3 inch lean to the right. and a bit lower to the front (half a bubble) when one dumps the air you would not think the air bags remain inflated, hence why dump the air at all? or does air remain in the bags and there is a leak on the right side? confused.
  • Friction in the suspension doesn't let it settle completely when you let out the air. Then over the next few hours it settles further. I don't think you have a problem.
  • Ivylog's avatar
    Ivylog
    Explorer III
    How are you letting the air out of the system? With air leveling I can let all the air out which lowers the MH down. You have a air leak which soapy water should find.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
