dougrainer
Apr 16, 2016Nomad
If you see no leaks(probably not since the previous owner had the same problem), you have (depending on the brand of the slide system/pump), a solenoid at the pump leaking internally or the slide cylinder/s are leaking internally. It is also possible one of the electric solenoids AT the pump is not shut tight. They usually have a manual release on the solenoid. Your time frame points to a not tight solenoid. Most rooms that drift, takes 10 to 24 hours and usually only a few inches. Hyd rooms require constant pressure to stay open and retracted. How far does the room retract? Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
