TeryT's avatar
TeryT
Coating a TPO (vinyl) Roof
Our TT is 13 years old. The vinyl TPO roof is still in decent shape, even though it sits out in the Phoenix heat (mostly) year round. Lately I've been wondering what to do when the vinyl starts going south.
From what info I've gathered, it looks like replacement would be in the $3-4k range for this trailer, which is 7.5' x 20'.
I then got excited because I read about people using "Liquid Rubber" (or Liquid Roof?) by ProGuard. Has anyone used this product on a TPO RV roof, and what has been the result? (somewhere I read that TPO roofs might require a special version of this product . . .)
Also, what is the coverage rate?
Thanks!
  • TeryT wrote:
    FlexArmor - Sprayed on by pros, costly, lasts 10-15 years & lifetime leak guarantee
    how does this differ from rhino/linex?
    bumpy
  • So here are the products I've heard about so far here and on other threads, and basic comments:
    APPLIED BY PROS
    Rhino Liner - Pricey, not great adhesion over non-metal & flexible surfaces (as reported by one person on another thread & others)
    FlexArmor - Pricey, lasts 10-15 years & lifetime leak guarantee
    Latex Elastomeric types DIY
    Hengs - one source says OK over TPO, another says no. May need a recoat 3-4 years in desert
    Elastomeric (Henry 287, 687, et. al.) - recoat every 4-5 years. Actually not recommended for RV roofs (but some have used it for that)!
    Solvent Based DIY
    Inland Coatings RC-2000 Found this on the web - ANYONE USED? (one person on another thread recommended this) Says good for TPO and all RV roofs and without primer. 15 year guarantee
    Silicone (e.g., Henry's 887 Tropi-Cool) - ANYONE USED THIS ON AN RV? Henry says it's 887 can do RV roofs including TPO. I wonder how this is to walk on or to repair (will anything other than silicone stick to it for repairs, like Eternabond Tape). . .?
    Superior RV Liquid Rubber - Good for TPO with no primer.
    Someone in another thread recommended this product. Appears to be like Inland Coatings and perhaps also LiquidRoof. 15 year guarantee
    LiquidRoof - must use primer over TPO (product also requires catalyst). Looks like about 5 year longevity before a recoat is probably needed. (Moderator Extraordinaire Barney gives a real nice report of applying this product in the 2nd thread linked here!)
    Some other good threads on this topic:
    One recent RV roof thread
    In-depth RV roof recoat thread started in 2011
  • does LIne-x have better adhesion? what surface preparation is done/needed?
    bumpy
  • I would recoat it with your choice of the liquid roof coatings, this will protect what is left of the good roof you currently have.
    It is easy to apply with a paint roller, just clean the roof well.
    Your seams and those from roof to siding need attention every year or two, re-caulk those (though not caulk, use the specific camper product for that).
    I have an aluminum roof with small holes, and used the Eternabond tape on the holes and coated it twice with the liquid. Looks great and no leaks.
    A new roof on an old camper sounds like a bad idea money-wise. Extend the life with the coating, and maybe the roof outlives the camper.
  • Bumpyroad wrote:
    TeryT wrote:
    Bumpyroad wrote:
    I'd look into rhino lining et.al myself.
    bumpy
    Thanks. So it looks like that product is just a few years old. Have you used it? It says it can keep the RV "up to 20 degrees cooler."
    Does it have to be professionally applied, since it's a spray on?
    Also, any idea of cost?
    Rhino Lining RV Roof
    I haven't used it but do a search, lots of previous discussion.
    makes a permanent fix, not a band aid.
    bumpy
    A previous quote said this about Rhino:
    ktmrfs wrote:
    myself and several others have put rhino/linex etc. over plywood decking in toyhaulers and cargo trailers. We all have mixed feeling on it. Unlike in a truck bed, adhesion is not a strong point. while it's almost impossible to get these off a scuffed up metal base, over plywood adhesion is marginal. if it starts to come loose at an edge it is not hard at all to pull it off by hand. Thats after the installers claimed they have specific directions from rhino/linex etc. on how to install over plywood and it will stick as well as a truck bed.
    yes it makes a good floor coating, easy to clean, great for toyhaulers, etc. but we all have to be careful about adhesion issues.
    In all the cases it seemed to adhere real well for a few years, then after temp cycling, vibration etc. lifting at the corners
    Found on this page
  • TeryT wrote:
    bumpy
    bumpy
  • NMDriver2 wrote:
    Hengs is what I used and it does not need a primer before using it on a TPO roof like Liquid Roof does.
    Oh that's interesting - Proguard advertises their "Liquid Roof" as the only liquid rubber product . . . hmmm
    How long ago did you do your roof?
  • Hengs is what I used and it does not need a primer before using it on a TPO roof like Liquid Roof does.
    bumpy
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 05, 2025
