theoldwizard1
Feb 15, 2021Explorer II
What are you using to measure the voltage ? The gauges on you dash are not very accurate.
Constantly >14.0V is actually not "normal" ! After running for 5-10 minutes, the voltage should be <14.0V
Make sure all battery cable connection are clean and tight. Constant high charging voltage could also mean your battery is on its last legs.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
