j-d's avatar
j-d
Explorer II
Jun 29, 2013
Coleman A/C Motor Serviceable?
The Fan Motor in our Coleman Mach 15000 (Model 8335B8914 Serial 030218531) seized up tonight. I had a Zoom Spot Oiler onboard so up I went at 2313, no moon, Harbor Freight flashlignt. The oil wouldn't release the stuck shaft even though I pulled the motor/fan back and oiled the inside fan end as well as the outer fan end. So I gave it one poof of WD-40 and it released immediately. Added some oil and buttoned it up.
OK the question: If I remove the motor and the fans from the motor shafts, can I get the motor apart to clean and lube the bronze bearings? The fasteners I can see look like rivets, but they could be screw heads (like carriage bolts) with nuts on the other end. If I can get it apart (and back together!) I'm sure I can lube it properly.
It's a FASCO motor 1/3-HP 2-Speed Type U18481, E0802. Coleman/RVP Part Number is 1468-3069
  • Seem to recall the motor itself isn't expensive - hard part is getting it out. Search feature should give you some threads discussing how to replace motor.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
