- TNRIVERSIDEExplorerMy Coleman CTS196RD has the bypass located on the back of the water heater. I can get to it by raising my jack-knife couch and removing a top cover. Coleman Techs have been great to help. Give them a call if you need more help.
- 1492ModeratorMoved from Forum Technical Support
- Old-BiscuitExplorer IIIYou have to access the backside of WH.......
IF you have a bypass it could be just a 1 valve, a 2 valve or 3 valve system
1 valve set up (a 3 way valve on cold inlet with check valve in nipple of hot outlet----change valve position to bypass)shown in service mode
2 valve set up ( two 3 way valves.....one on cold inlet & one on hot outlet----change both valve positions to bypass)
shown in bypass mode
3 valve set up (valve on each line cold inlet/hot outlet/bypass line---change valve position on all three to bypass)could be in service or bypass (depends on what is open/closed
There are also 'modified' systems.
This is a 1 valve modified to a 2 valve (check valve in hot out removed---valve installed)shown in service mode (3 way valve handle parallel with cold inlet line)
- irbetanExplorerNo my Manula is general, no locations. My old rig had in the closet, but my new one i dont know I guess it would have help if I give my make and model, I have a Coleman CTU271RB.
- Ka_RonExplorerOurs is on the top of the tank.
Having said that, I image all manufacturers would be different.
Do you have a manual for your unit, it may show in there
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
