vexter0944's avatar
vexter0944
Coleman Mach 15000 BTU A/C Issue - Electrical in Nature
I have a mobile catering/vending rig built in 2012. It has a Coleman Mach 15K A/C unit for keeping us cool while cooking/serving.
Up until a couple of weeks ago, it has been perfectly fine - I use a Honda EU6500is series generator to handle everything in our trailer from fridge, to A/C to warming units and have never had a problem with overloading the generator at all.
A couple of weeks ago, I setup like normal and every time the A/C would kick on - the generator would show overload and shut off A/C current. When I moved a few items off to a second generator all was fine, but the EU6500 was running like it had some crazy load attached to it - which it didn't.
I thought maybe something had happened to our trusty EU6500, so I purchased a Yamaha generator (EF3000iSEB). (not meant to 'replace' the Eu6500 - just as a secondary backup and as a smaller use generator for when I don't need to run steam tables etc - like when I'm catering - instead of lugging around the beast I can bring this and have 30A service for lighter cooks/jobs.)
I tried using it this weekend on the 30A circuit and was only running some lights and small stuff and the Coleman A/C. The minute the A/C tried to kick on - man it looked like a poltergeist had moved in to the trailer - lights flickering (fluorescent) and it killed my kill-a-watt meter. So I re-adjusted (since the show had to go on because I was catering) and got some power from an outlet (20 amp) and moved everything off the Yamaha to shore power except for the A/C - now when the A/C would kick on the generator would run full tilt when I know it only needs like 18A or so to 'run' (I realize the need for more when it's starting..) - but I have one of the EMS-HW50C units installed, so I've seen in the past when on 50A 220V shore power how many amps I pull when operating etc.
So I think and am pretty sure, something is going on with the Coleman A/C unit because the problems only arise on both generators, when the A/C unit kicks on.
any ideas of where I should turn or try to look to fix this? I'm NOT a mechanic, but if it's just a part to replace/check - I can get that done. If not - I don't want to get screwed for a new A/C unit if I take it in to be looked at.
Any help/ideas would be much appreciated!
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
