dougrainer
May 25, 2022Nomad
Since you have mechanical controls, I would suspect a BAD tstat. The points are opening and closing too fast and causing compressor short cycling. The bad thing about mechanical tstat systems is there is no 3 minute time delay built in the system for stopping short cycling. The ONLY difference between HP and COOL is the system reverses the coolant. So, if functional on HP and, then the problem points to the tstat, not a capacitor or compressor. Doug
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
