dougrainer
May 25, 2022Nomad
To the OP, MAKE SURE THE COLD TEMP SENSOR IS INSTALLED IN THE CORRECT AREA OF THE RETURN AIR PLENUM. If it too close to the evap it will cause short cycling. Also, if the separation plenum gasket is NOT installed correctly or has air leaks(will be cold air flowing to where the temp sensor is), that will also cause short cycling. Doug
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
