dougrainer
Jun 09, 2019Nomad
twodownzero wrote:dougrainer wrote:
If the compressor is running, then your Unit is shot and the upper unit needs replaced. Doug
I haven't seen an A/C compressor that ran in a unit that didn't produce any cold air yet.
Really, You base your comment on what expertise? I am basing my comment on 40 years and still working as a RV Tech. IF the compressor is Running, and NOT producing cold air, the Coolant is gone or the compressor valves are bad. Either way, you replace the upper AC unit. Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
