dougrainer
Jul 14, 2014Nomad
hardkillinpete wrote:
Will the frame mounts line up or will I need to replace frame as well?
ALL RV roof mount AC's use the standard 14 by 14 inch hole in the roof. BUT, you will have to get the COMPLETE AC and mount kit if you are changing brands. The wall tstat wiring will be OK as you will only be using 3 of the 6/7 tstat wire harness.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 21, 2026
