j-d's avatar
j-d
Explorer II
Jun 17, 2016
Coleman Mach Compressor Failing?
This is a Mach 15 (15,000-BTU) Cool-Only A/C factory installed in 2003. Today, in 95-degree temps, the compressor has been stopping, and needs 15-minutes or so to re-start. This suggests that its internal thermal protection isn't holding. Or, the compressor is running above its design temperature.
I read Run Amps from a Spec Sheet and it's "12.6 Full Load." What I'm seeing on my...harborfright...AC Ammeter is closer to 17. Started around 12 after a cooldown but right now it's in mid-16's, since the sun has dropped a little.
Campground voltage has been as high as 119, no lower than 110, all afternoon.
Unit is clean, and seems to be cooling well. Compressor has a buzz sound in addition to a more normal hum.
The intake filters are recently replaced, but I can change them again. Can also install my new backup capacitor.
Anything else?
Should I be A/C shopping?
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
