RustyScupper's avatar
RustyScupper
Coleman Mach RV Comfort Thermostat
Yesterday getting the rig ready for the season and fired up the electric heat strip in the AC unit and it worked fine except that the propane furnace also came on.
I have the Coleman Mach RV Comfort Thermostat and I assume that it is the little selector slide switch is malfunctioning allowing both heat sources to run at the same time.
I have had issues in the past where the propane furnace would run and continue past the heat setting and not shut off.
Any thoughts if I am on the right track?
