MrWizard
Sep 25, 2017Moderator
your only going to be able to use (1) hot leg
max 23 amps at 120v
unless you have severe voltage drop on the duplex at the stick house
i would just the stick house 20amp duplex and save the gasoline cost for the generator
if you really need all 23 amps, and buying gas is not to be worried about, go ahead and use the genny, BUT be sure you get or make the correct adapter
only 3 wires, 1 white, 1 green, 1 black
do not use (2) hots and burn out TT applances such as the converter, the fridge , the TV , the water heater etc.. with 230v
max 23 amps at 120v
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
