JamesJudasPries
Mar 19, 2015Explorer
Thanks guys!
Yes, that is the plan isolate neutral and ground on 120v. The specs I listed for current draw came from the manuals of the appliances, but the appliance are old probably from the mid 1980s so maybe the modern equivalents draw more? Not sure.
I think i will install a simple 5 led battery meter voltmeter . You know, one of those empty , low ,med ,full/charging idiot lights. Probably 18 gauge wire and a 1 amp fuse in the panel. I think that's all the guy will care about.
Yes that is the plan, use 14/2 stranded rv cable for the 12v branch circuits , maybe use some. 12 gauge for the fridge.
I will find out the max size wire for the samlex 300w inverter terminals. Maybe #6?
