MEXICOWANDERER
Mar 19, 2015Explorer
I agree. Stranded THNN is hard to beat. I used 12-gauge with #6 spade terminals for the receptacles. Makes wiring a whole lot easier. Spec grade receptacles throughout. Cole-Hersee rocker switches. Red + yellow for the 12-volt stuff - same as YSB yacht color coding.
Battery compartment is for batteries only. Passed cables through a bullhead and used Del City plastic strain relief threaded bushings. Buss bars and inverter on the other side. Zero corrosion. Converter charger, Klixon switch breakers with LED fault indicators across both AC and DC breakers.
Looks like you're going to have a nice setup. The way you want it and trouble-resistant. Have a blast - it's fun!
